Inleiding
In this guide, we will walk you through replacing the home button on the Samsung Galaxy Tab E 9.6 (Verizon). As a side note, before accessing the home button for replacement, both the front and back panels must be removed. We will demonstrate how to remove each panel prior to replacing the home button. Listed to the right are the necessary tools for this project.
Wat je nodig hebt
Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
Unlock the ZIF connector to release ribbon cable that lays across the battery.
To reassemble your device, reverse the steps in the instructions.
Één andere persoon heeft deze handleiding voltooid.
