Ga door naar hoofdinhoud
Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Back Casing: stap 1, afbeelding 1 van 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 2, afbeelding 3 van 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 3, afbeelding 3 van 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Front Panel: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement, Front Panel: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
    • To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
  5. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 5, afbeelding 1 van 1
    • Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
  6. Samsung Galaxy Tab E 9.6 Verizon Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
    • Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Dave Dorzback
626 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-4, Cagle Fall 2016 Lid van USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Leden
14 handleidingen geschreven
Één opmerking
To install the new screen, install the connector at the top first and dry fit before installing and make sure you align the Button and Camera.
Oscar C - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 4,427
