Ga door naar hoofdinhoud
Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement, Back Casing: stap 1, afbeelding 1 van 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 2, afbeelding 3 van 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: stap 3, afbeelding 3 van 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
Conclusie
Dave Dorzback
626 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-4, Cagle Fall 2016 Lid van USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,707
