Ga door naar hoofdinhoud
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 2, afbeelding 2 van 2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 3, afbeelding 2 van 2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: stap 4, afbeelding 2 van 2
    • The picture illustrates what the device should look like once the back camera is removed.
Conclusie
Tingting Liu
25 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-4, Cagle Fall 2016 Lid van USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,164
