Inleiding
The screen of the Samsung Galaxy Tab E 8.0 may become damaged if the device is dropped or struck by a hard object. This guide shows how to replace the tablet's screen, which is attached to the front panel.
Wat je nodig hebt
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Use the tweezers to lift the switch connecting the back camera to the motherboard.
Use your hand to remove the back camera from the motherboard.
Use the tweezers to lift the switch connecting the front camera to the motherboard.
Remove the front camera from the motherboard by lifting with the tweezers.
Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
Release the strap from the switch by lifting the strap with your hand.
Use the tweezers to lift the flap on the left end of the battery and pull up with your hand to remove the battery.
Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
You will need to use an iOpener or apply heat to separate the digitizer, especially if the glass is shattered. The bottom near the home button and the entire top portion has thick strips of black adhesive.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
I am working on a 7” lite E. Is the procedure about the same?
deffently got to apply heat to that front screen due to the adessive bewhind or mostlikly crack the screen
Trent Weaver - Antwoord
