Ga door naar hoofdinhoud
Samsung Galaxy Tab E 8.0 Audio Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Back Camera: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Back Camera: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Front Camera: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Front Camera: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Front Camera: stap 3, afbeelding 3 van 3
    Koop
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Motherboard: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Motherboard: stap 4, afbeelding 2 van 2
    Koop
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 5, afbeelding 2 van 2
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 6, afbeelding 2 van 2
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 7, afbeelding 2 van 2
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 8, afbeelding 2 van 2
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab E 8.0 Audio Jack Replacement: stap 9, afbeelding 2 van 2
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
  10. Samsung Galaxy Tab E 8.0 Audio Jack Replacement, Audio Jack: stap 10, afbeelding 1 van 1
    • Use the soldering tool to remove the audio jack.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christian Bloemhof
1.102 Reputatie
7 handleidingen geschreven
Cal Poly, Team S13-G4, White Fall 2018 Lid van Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 691
