Ga door naar hoofdinhoud
Samsung Galaxy Tab A 9.7 Speakers Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: stap 2, afbeelding 2 van 2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Conclusie
Paulina Nguyen
982 Reputatie
6 handleidingen geschreven
Cal Poly, Team S1-G3, Livingston Spring 2017 Lid van Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Lid
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 1,470
