Ga door naar hoofdinhoud
Samsung Galaxy Tab A 9.7 Rear Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 9.7 Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove one of the iFixit opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  5. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Disconnect all wires and strips that connect the motherboard to any other part of the device with an iFixit opening tool.
    • Lift up gently on all wires and strips.
  6. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Lift the motherboard out of the back panel using an iFixit opening tool.
    • Be gentle when wiggling the motherboard out from underneath the battery's protective edge.
  7. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Pull off the rear camera on the back of the motherboard and replace.
Conclusie
Makenzie D'Elia
313 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Hovde Spring 2019 Lid van IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 258
