Ga door naar hoofdinhoud
Samsung Galaxy Tab A 9.7 Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove one of the opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the strip from the motherboard with the iFixit opening tool.
  5. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  6. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 6, afbeelding 2 van 2
    • Remove both side pieces using one of the the iFixit opening tools.
    • Lift up the headphone jack port with the iFixit opening tool as well.
  7. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Pull up the headphone jack port carefully and replace.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Justin Osborn
154 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G3, Hovde Spring 2019 Lid van IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 414
