Ga door naar hoofdinhoud
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 3, afbeelding 3 van 3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Remove the auxiliary port from the case.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Bradley Watson
1.079 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-4, Passmore Spring 2017 Lid van USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 59
Altijd: 3,997
