Ga door naar hoofdinhoud
Samsung Galaxy Tab A 10.1 Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 10.1 Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement: stap 2, afbeelding 2 van 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Screen Replacement, Disconnecting the battery: stap 3, afbeelding 1 van 1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab A 10.1 Screen Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab A 10.1 Screen Replacement: stap 5, afbeelding 3 van 3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Screen Replacement, Battery removal: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement, Battery removal: stap 6, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Screen Replacement, Motherboard: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab A 10.1 Screen Replacement, Motherboard: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab A 10.1 Screen Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
    • Slide the orange ribbon cables out of the ZIF connectors.
    • Remove the front-facing camera.
  8. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the headphone jack from the motherboard.
    • Use a Phillips # 000 to remove six 4mm screws.
  9. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement: stap 9, afbeelding 2 van 2
    • Lodge the plastic opening tool under and lift the motherboard out of the tablet.
    • Be careful not to snag any connectors.
    • Remove the metal bracket that was underneath the charging port and set aside.
  10. Samsung Galaxy Tab A 10.1 Screen Replacement, Screen: stap 10, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Screen Replacement, Screen: stap 10, afbeelding 2 van 2
    • The screen may crack during removal, so be wary of broken glass. Apply heat as necessary around the edges of the screen to loosen the adhesive, but be careful not to melt the plastic frame of the tablet.
    • Starting on the side of the tablet near the bottom, heat the area and insert a metal jimmy or opening pick between the digitizer and the frame.
    • Separate the adhesive on the bottom of the tablet first, then work up the sides. The digitizer ribbon cable is located at the top and passes through a slot in the mid-frame. It is easily torn or damaged in the final stages of removing the glass.
    • If the glass is intact and you intent ro reuse it, take care not to insert the jimmy further than the width of the black screen border or you risk damaging the digitiser, which is a thin plastic film stuck to the bck of the glass.
    • The adhesive tends to stick to the plastic mid-frame rather than the glass but it will separate more easily and cleanly from the midframe if you can start it lifting at one point. This will also reduce the risk of damaging the digitiser film.
  11. Samsung Galaxy Tab A 10.1 Screen Replacement: stap 11, afbeelding 1 van 1
    • Turn the tablet over and lodge the plastic opening tool under the screen to take it out of the device.
    • The LCD panel is stuck to the mid-frame with double sided tape. Lift gently and progressively, giving the adhesive time to give way.
Conclusie
44 andere personen hebben deze handleiding voltooid.
Isabella Li
2.364 Reputatie
7 handleidingen geschreven
Cal Poly, Team S15-G6, Livingston Fall 2017 Lid van Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Leden
26 handleidingen geschreven
21 opmerkingen
Will be trying this in the next couple of days, see there was no heat gun used to take the front glass off, I’m only replacing the LCD so does the touch glass need warming to remove or does it just jimmy off?
tcatt - Antwoord
I would Personally HIGHLY RECOMMEND Heat.
this Guide Perturbs me slightly.It never detaches the battery from motherboard and misses a couple of the Connectors it feels like its skipping steps.
iCovers Customer Service -
After replacing the digitizer, my soft keys do not function. The home button works just fine, but i cannot press the back button or the recent application button. Would this be due to a faulty digitizer? Or could it possibly be a faulty ‘ daughter board “? ( not positive if the home button working excludes this theory )
Lance Basinger - Antwoord
Same problem here. Did u fix a fix?
Jesse Martucci -
Same here HAS ANYONE SOLVED THIS ISSUE
Collin Babb -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 122
Afgelopen 30 dagen: 544
Altijd: 133,245
