Ga door naar hoofdinhoud
Samsung Galaxy Tab A 10.1 Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
    AWESOME!! I was trying to open it from the “NOT OK” place and you saved me to broken the screen… thanks!!
    David Leiva - Antwoord
    No problem, enjoy.
    Roger L. Ortiz -
    Felt it was easier for me to do it from the middles out.
    Tanin Garcia - Antwoord
    @rogerlortiz You two seem to be miscommunicating. The author points out the location between the digitizer and frame in which to place a tool. While @Tanin Garcia, whom no longer seems to be member, was pointing out where along the edge from corner to corner it was best to start the separating process.
    B. A. Computer Services -
    Important: the display is sourrounded with a plastic frame. You need to get beween this frame an the backcover (not directly at glass edge as I tried it first and almost broke the glass). Get a closeup picture of it to clarify.
    Oliver Dawid - Antwoord
    wer lesen kann, ist klar im Vorteil - ich hab die SD-Karte drin gelassen. Hat aber funktioniert…
    Thomas Wolter - Antwoord
    Don’t use a very small flathead screwdriver as a spudger. Just shattered the screen :(
    nikvoss - Antwoord
    Yes, shattered the screen. To the garbage, it goes. A little knowledge is a dangerous thing. This a repair better suited for a professional repair! Thanks for helping me make the decision to get another one!
    vancega - Antwoord
  2. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Disconnecting the battery: stap 3, afbeelding 1 van 1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
    BEWARE!!! later on Samsung tablets the tab holding the main cable (marked “MAIN”) breaks as soon as you attempt to lift the tab to remove the ribbon! I reckon Samsung designed this breakabloe tab to not only avoid the warranty, but the render the tablet useless!
    graham chapman - Antwoord
    Happened to me also, in order to replace that broken tab, do you think it will be necessary to replace the motherboard? I highly doubt we can find the parts to fix (replace) the flip-tab.
    jeanuhlik -
    I also had this problem, the connector broke, even if i was very careful, i still can use the tablet, i pushed the “main” cable in place and used a little bit of hotmelt glue to hold it in place.
    Yannick - Antwoord
    I tried using aluminum foil to make the connection but it didn’t help at all, how did you attach it with the glue gun???
    jeanuhlik - Antwoord
    LOOK what I found!!! its the replacement for the connector we broke!!!https://www.parts4repair.com/samsung-gal...
    i just wonder how u gonna solder this tiny thingie
    Mike Muley -
    I wish I had read this thread before I removed the cable and broke the connector. Unfortunately I have not been able to reattach the cable and my tablet is dead.
    If there is no way to remove this cable, why is this fix even posted here? I find this exceptionally uncool!
    Derek N. Eder - Antwoord
    Whoever broke the connector was trying to open it the wrong way. I have oil spilled in mine after I replaced my screen and digitizer together if you only replace the screen it is more difficult. I say changing both together is simpler. And I will share a pic either way I just might mess up MY connector. To be continued
    909 - Antwoord
  4. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Lift the retaining tab and withdraw the black LCD ribbon.
    It's possible to replace only the lcd cable connector? Ist das möglich nur das Flachbandkabel zu tauschen?
    Lima - Antwoord
  6. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Battery removal: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Battery removal: stap 6, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Motherboard: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Motherboard: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
    • Slide the orange ribbon cables out of the ZIF connectors.
    • Remove the front-facing camera.
    This step omits the disconnection of the battery from the motherboard , which is shown disconnected in this picture but was connected in the previous step
    Christopher Ford - Antwoord
    Thanks for bringing this to our attention. We added the relevant battery disconnection steps—hope this helps!
    Kristen Gismondi - Antwoord
    If the model you are working on is the T585 you will need to carefully pry up the blue antennae cable and disconnect the sim card slot from the motherboard.
    Brendon Gould - Antwoord
  8. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the headphone jack from the motherboard.
    • Use a Phillips # 000 to remove six 4mm screws.
    die ganze Platine musste ich gar nicht ausbauen. Ich konnte die Kopfhörerbuchse vorsichtig mit einem kleinen flachen Schrubendreher lösen.
  9. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement: stap 9, afbeelding 2 van 2
    • Lodge the plastic opening tool under and lift the motherboard out of the tablet.
    • Be careful not to snag any connectors.
    • Remove the metal bracket that was underneath the charging port and set aside.
    Replacing the broken screen, I stupidly unhooked the LCD with a metal screwdriver. It makes the sound of coming on but no picture. Is that the motherboard?
    MARGARET - Antwoord
    I replaced screen once before and had no problem except using a screwdriver this time.
    MARGARET - Antwoord
    I have tab a charging and show on screen but not starting at all motherboard water damage I clean all there any way make it start by motherboard with out power button
    waleed nawzad - Antwoord
    TIP: Before next step (or sooner), cover cracked/broken glass with transparent tape to avoid (I didn't) or minimize small shards of glass falling into work area and onto your clothing.
    Bruce Grant - Antwoord
  10. Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 1 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 2 van 3 Samsung Galaxy Tab A 10.1 Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 3 van 3
    • Use Phillips # 000 to remove two of the 4 mm .3 cm screws around the headphone jack.
    • Lift the metal piece that is covering the headphone jack from one of the sides.
    • Lift out the headphone jack.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Isabella Li
2.376 Reputatie
7 handleidingen geschreven
Cal Poly, Team S15-G6, Livingston Fall 2017 Lid van Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Leden
26 handleidingen geschreven
5 opmerkingen
where can i buy a new piece of headphone jack for my tab A?
Sven Leysen - Antwoord
I just used this guide to change the headphone jack on a Galaxy Tab A 10.1 SM-T580.
After taking the back off (Step 2) the headphone jack is fully accessible (Step 10).
I didn’t need to remove anything else, so Steps 3-9 inclusive were not required for me.
Matt Griffiths - Antwoord
Very helpful instructions.
I likewise found the headphone jack to be fully accessible (SM-P585Y). The metal cover sticks a bit, but it’s only held down by the two screws. The headphone jack itself rests on top of a slightly adhesive pad.
Benny Lawrence - Antwoord
Galaxy Tab A6 2016 - SM-T580
Die Kopfhörerbuchse habe ich bei Ebay (lt. Angebot neu) für unter 5€ gekauft. Anstelle des Plastikwerzeugs habe ich ein normales dünnnes Schmiermesser genommen. Mein Tablet is ja auch schon was älter. Von daher war es mir egal, was passiert, wenn ich nicht das Plastikwerkzeug benutze.
Gehäuse geöffnet, die beiden Schrauben an der Buchse rausgeschraubt und dann vorsichtig mit einem flachen Schraubendreher gelöst. War offensichtlich mit einer Art doppelseitigem Klebeband fixiert.
Buchse getauscht, zusammengebaut, getestet - funktioniert!!!!
Vielen Dank für die tolle Anleitung, die einem Mut macht, es selbst zu probieren.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 74
Altijd: 9,970
