Ga door naar hoofdinhoud
Samsung Galaxy Tab 8.9 LCD Screen Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Insert Opening tool: stap 1, afbeelding 1 van 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Insert second tool: stap 2, afbeelding 1 van 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 LCD Screen Replacement, Display: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Slide out the yellow flexible ribbon cable to disconnect it from the motherboard.
  7. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove green tape from lcd connector.
  8. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Pull lcd cable out of connector.
  9. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Slide metal tool around perimeter to release glue.
    • Be careful not to damage the yellow ribbon cable.
  10. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Pull glass cover from main frame.
  11. Samsung Galaxy Tab 8.9 LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Pry screen from housing.
Conclusie
Eric Bird
543 Reputatie
5 handleidingen geschreven
IUPUI, Team S4-G2, Harley Spring 2017 Lid van IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 1,538
