Onderdelen
Geen onderdelen nodig.
  1. Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Slide the second plastic opening tool along the edge of the device to separate the back cover.
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Using your hands, remove the back cover.
    • Using your hands, remove the back cover.
  6. Camera can be found near the top center of device.
    • Camera can be found near the top center of device.
  7. Using Spudger, lift connector from mother board Using Spudger, lift connector from mother board
    • Using Spudger, lift connector from mother board
  8. Lift camera and remove from device. Lift camera and remove from device. Lift camera and remove from device.
    • Lift camera and remove from device.
Conclusie
Aleezee True
520 Reputatie
3 handleidingen geschreven
USF Tampa, Team 11-4, Blackwell Fall 2014 Lid van USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Leden
10 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 3
Altijd: 280
