Ga door naar hoofdinhoud
Samsung Galaxy Tab 8.9 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: stap 2, afbeelding 1 van 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: stap 5, afbeelding 3 van 3
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 8.9 Battery Replacement: stap 6, afbeelding 2 van 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 8.9 Battery Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 8.9 Battery Replacement: stap 7, afbeelding 3 van 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: stap 8, afbeelding 1 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: stap 8, afbeelding 2 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: stap 8, afbeelding 3 van 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: stap 10, afbeelding 1 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: stap 10, afbeelding 2 van 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: stap 10, afbeelding 3 van 3
    • Use a spudger to lift up and separate the battery from its housing.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Dan D
160 Reputatie
1 Handleiding geschreven
USF Tampa, Team 11-4, Blackwell Fall 2014 Lid van USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Leden
10 handleidingen geschreven
Één opmerking
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 21
Altijd: 4,617
