Inleiding
Use this guide to replace the rear camera.
Wat je nodig hebt
Use the flat end of a metal spudger to pry the two plastic tabs near the dock connector off the rear case.
Insert a plastic opening tool near the bottom left edge of the rear case.
Use your plastic opening tool to gently create a small gap between the front panel and the rear panel near the bottom left edge.
Run the plastic opening tool along the left side of the perimeter to create a bigger gap between the front panel and the rear panel.
Insert two guitar picks into the small gap created by the plastic opening tool.
Insert the plastic opening tool into the dock connector and wedge it underneath the front panel/motherboard assembly.
Thrust the plastic opening tool downwards to create a gap near the lower left corner of the front panel assembly.
Insert a guitar pick into the newly created gap near the lower left edge of the Galaxy Tab.
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the motherboard.
