Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 2, afbeelding 3 van 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 3, afbeelding 3 van 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 4, afbeelding 3 van 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 5, afbeelding 1 van 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 7, afbeelding 3 van 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 8, afbeelding 2 van 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 9, afbeelding 1 van 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 10, afbeelding 2 van 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: stap 11, afbeelding 1 van 1
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: stap 12, afbeelding 1 van 1
    • Gently pry up on the speaker to disconnect the speaker from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 135
