Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 3 van 3
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
  5. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  6. Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Front Facing Camera Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
Conclusie
Ofelia Cruz
1.119 Reputatie
5 handleidingen geschreven
CSU Fullerton, Team 1-3, Bruce Fall 2015 Lid van CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 508
