Inleiding
This guide will show you the steps to follow when replacing the display on your Samsung Galaxy Tab 4 8.0 Verizon.
Gereedschap
Onderdelen
Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
Insert an opening pick in between the display screen and the display frame.
Disconnect battery first! (In this photo the battery has already been removed).
Gregg Stanley - Antwoord
There is also another connector directly to the right (in this photo) that needs to be disconnected as well (this picture shows it under the logic board, so this has already been removed and replaced before the photo was taken).
