Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 2, afbeelding 2 van 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 3, afbeelding 2 van 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 5, afbeelding 1 van 1
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 6, afbeelding 2 van 2
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: stap 7, afbeelding 3 van 3
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Ofelia Cruz
1.119 Reputatie
5 handleidingen geschreven
CSU Fullerton, Team 1-3, Bruce Fall 2015 Lid van CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Leden
12 handleidingen geschreven
3 opmerkingen
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Cameron - Antwoord
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - Antwoord
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 26,270
