Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Briana Honeycutt
432 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-3, Remmell Fall 2015 Lid van USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Leden
12 handleidingen geschreven
4 opmerkingen
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Antwoord
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Antwoord
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 18,052
