Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 7.0 Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 6, afbeelding 2 van 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - Antwoord
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 3 van 3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Aubrey Goodwin
2.700 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Remmell Fall 2015 Lid van USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Leden
12 handleidingen geschreven
3 opmerkingen
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Antwoord
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Antwoord
टॅब पार्ट खरेदी करना है मुझको
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 4,268
