Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 7.0 Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 5, afbeelding 2 van 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: stap 6, afbeelding 2 van 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: stap 7, afbeelding 3 van 3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Aubrey Goodwin
2.700 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Remmell Fall 2015 Lid van USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Leden
12 handleidingen geschreven
3 opmerkingen
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Antwoord
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Antwoord
टॅब पार्ट खरेदी करना है मुझको
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 4,268
