Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 7.0 Battery Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Edgard R Baladron
432 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-3, Remmell Fall 2015 Lid van USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Leden
12 handleidingen geschreven
3 opmerkingen
This is for a cell phone, not a tablet. Why?
ckmjunk - Antwoord
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 42
Altijd: 26,568
