Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 2, afbeelding 1 van 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 4, afbeelding 1 van 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 5, afbeelding 1 van 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 6, afbeelding 1 van 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: stap 7, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: stap 7, afbeelding 2 van 2
    • Pry up and disconnect the power and volume button press-fit connector with the flat end of a spudger.
  8. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: stap 8, afbeelding 1 van 1
    • Remove the power and volume button ribbon cable.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Blake Klein
70.528 Reputatie
50 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 3,637
