Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 2, afbeelding 1 van 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 4, afbeelding 1 van 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
    Take note of the red warning comment! Very easy to pull up the connector off the board!!!
    Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
    Ashley Lahm - Antwoord
  5. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 5, afbeelding 1 van 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 6, afbeelding 1 van 1
    • Once the battery is loose, lift it out of the device.
    I’m new to working on these devices, but I am wondering why the battery is removed? Is that necessary for this repair? Thanks!
    Tuvy Guss - Antwoord
    Better disconnect battery before any repairs, therefore reducing the possibility of a short-circuit which could destroy the motherboard.
    Tian Lai Li - Antwoord
    Isolation tape can also be placed over the connection after disconnecting to prevent any accidental short-circuit mishaps, thus reducing the need to remove the battery.
    Cheers Wayne
    Wayne Lyell - Antwoord
  7. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: stap 7, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: stap 7, afbeelding 2 van 2
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  8. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Blake Klein
70.531 Reputatie
50 handleidingen geschreven
2 opmerkingen
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - Antwoord
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 7,027
