Ga door naar hoofdinhoud
Samsung Galaxy Tab 4 10.1 Home Button Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Home Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 2, afbeelding 1 van 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 4, afbeelding 1 van 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 5, afbeelding 1 van 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 6, afbeelding 1 van 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Digitizer: stap 7, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the home button.
  8. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 8, afbeelding 1 van 1
    • Use an iOpener to weaken the adhesive around the display.
  9. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 9, afbeelding 1 van 1
    • Wedge an opening pick between the digitizer and display frame.
    • Slide the opening pick around the perimeter to separate the two pieces.
  10. Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Home Button Replacement: stap 10, afbeelding 2 van 2
    • Lift and remove the digitizer.
  11. Samsung Galaxy Tab 4 10.1 Home Button Replacement, Home Button: stap 11, afbeelding 1 van 2 Samsung Galaxy Tab 4 10.1 Home Button Replacement, Home Button: stap 11, afbeelding 2 van 2
    • Lay the digitizer face down and remove the home button ribbon cable.
    • Remove the exterior home button.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Blake Klein
70.510 Reputatie
50 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 3,709
