Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 Kids Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 2, afbeelding 2 van 2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: stap 4, afbeelding 2 van 2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
Conclusie
4 andere personen hebben deze handleiding voltooid.
ajhoffman
182 Reputatie
5 handleidingen geschreven
USF Tampa, Team 2-6, Nance Fall 2016 Lid van USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Leden
10 handleidingen geschreven
2 opmerkingen
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Antwoord
my screen broke
galixyman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,988
