Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 8.0 Front Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: stap 1, afbeelding 2 van 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: stap 2, afbeelding 2 van 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Battery: stap 4, afbeelding 1 van 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: stap 5, afbeelding 3 van 3
    • Take the plastic remover tool and gently lift the component free from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
anthony gonzalez
313 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-2, Brown Fall 2014 Lid van USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 698
