Onderdelen
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
After the battery is disconnected you may use your hands to pull out the battery. It may be a little difficult because there is adhesive on the backside of the battery.
Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
Één andere persoon heeft deze handleiding voltooid.
