Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 7.0 3G Battery Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: stap 1, afbeelding 3 van 3
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Samsung Galaxy Tab 3 7.0 3G Battery Replacement: stap 2, afbeelding 1 van 1
    • Once the backing has been pried off all around the device, remove the white backing.
  3. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: stap 3, afbeelding 3 van 3
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
  4. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Begin by removing the four designated 1.33x2.00 mm Phillips screws with the screwdriver, as shown in the first picture.
    • Once the screws are removed, use a pair of tweezers or the spudger to remove the battery connector.
    • Pull the battery connector up as shown in the second picture.
    • Once the battery connector is removed, you can remove the battery using the spudger as shown in the third picture.
    I found it easier to start with the USB. And like others, there was no need to remove the siding. The battery was held in with double-backed tape. Thanks
    John Keenliside - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrea Flores
1.516 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-30, Maness Fall 2014 Lid van Cal Poly, Team 14-30, Maness Fall 2014
CPSU-MANESS-F14S14G30
4 Leden
18 handleidingen geschreven
3 opmerkingen
Thanks for this guide. It was really helpful. I did not need to remove the silver siding to replace the battery. Is this step optional?
Mark
mrbaker1917 - Antwoord
I am glad this was useful mrbaker1917!! Yes, removing the silver sliding is optional but useful if you are trying to replace anything else on your tablet.
Andrea Flores - Antwoord
Good job Andrea!
AT&T told us to buy a new tablet; couldn't get batteries anymore. Usual no-nothing big box store employees selling on commission.......sheeesh!
You're the hero today!
Rock
good medicine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 17,458
