Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This disassembling guide is useful for many repair guides involving the device such as battery replacement, camera replacement etc..
Wat je nodig hebt
To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
Continue to pry off the white backing around the device, as shown in the third picture.
To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
22 andere personen hebben deze handleiding voltooid.
7 opmerkingen
i need the back panel
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Never buying a Galaxy Tab again!
