Wat je nodig hebt
Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
Insert an opening pick between the plastic frame and the screen.
Slide the opening pick around the perimeter of the screen.
Using the pointed end of a nylon spudger, pry upwards between the screen chassis and the auxiliary port.
Één andere persoon heeft deze handleiding voltooid.
