Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: stap 3, afbeelding 3 van 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 13, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: stap 13, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use nylon-tipped tweezers to remove the motherboard.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Corey Brown
8.826 Reputatie
11 handleidingen geschreven
3 opmerkingen
Great guide, project completed.
Edgar Merced - Antwoord
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - Antwoord
very easy to destroy the Galaxy. finicky to the max!
ein Stein - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 48
Altijd: 9,714
