Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Front-Facing Camera: stap 3, afbeelding 1 van 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  4. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
Conclusie
Corey Brown
8.832 Reputatie
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 879
