Ga door naar hoofdinhoud
Samsung Galaxy Tab 3 10.1 Battery Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Open Device: stap 1, afbeelding 1 van 1
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement, Ribbon Cables: stap 2, afbeelding 1 van 1
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery Screws: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement, Removal: stap 4, afbeelding 1 van 1
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
Conclusie
45 andere personen hebben deze handleiding voltooid.
Fabio
1.506 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-2, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-2, Duarte Fall 2014
UMASSD-DUARTE-F14S2G2
4 Leden
6 handleidingen geschreven
4 opmerkingen
is there a diference between the lte, 3g and wifi versions of the samsung tablet
Josh Robinson - Antwoord
thanks for the information. i will use it wisely.
Adelle Bradley - Antwoord
Battery changed, works fine !
Thank you for the tuto :-)
Sharky Billy - Antwoord
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
George Cooke - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 13
Altijd: 54,391
