Ga door naar hoofdinhoud
Samsung Galaxy Tab 2 7.0 Speaker Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 2 7.0 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Conclusie
Katija Tarailo
460 Reputatie
3 handleidingen geschreven
IUPUI, Team S3-G1, Harley Spring 2017 Lid van IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 755
