Ga door naar hoofdinhoud
Samsung Galaxy Tab 2 7.0 Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: stap 1, afbeelding 1 van 3 Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: stap 1, afbeelding 2 van 3 Samsung Galaxy Tab 2 7.0 Battery Replacement, Preparing Your Device: stap 1, afbeelding 3 van 3
    • Power the device down completely
    • Remove the SD card from the SD card slot.
    • Remoce the sim card from the sim card slot if you have the sim card versions show in one of ghr images
  2. Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the prying tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Be sure to unclip all of the clips on the back panel or it will be difficult for you to pull it off and may damage the tablet.
  3. Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery Flex Cable from its socket by placing the pry tool under the wires and gently prying it out.
    • When you are placing in the new battery, it helps to connect the socket first or else it becomes difficult to properly align once the battery is in place.
  4. Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 2 7.0 Battery Replacement: stap 4, afbeelding 3 van 3
    • Using the Phillips precision screw driver remove the six 4 mm screws holding the battery in place.
    • Once the battery is loose, remove as shown.
Conclusie
50 andere personen hebben deze handleiding voltooid.
Paul
2.183 Reputatie
4 handleidingen geschreven
15Gids Commentaar
thanks so much for this guide! Its easy to follow and may have just answered a question I've been asking myself for months.....
karmacroft - Antwoord
I have using my phone last 5 year its the Samsung galaxy tab 2. I have rooted my device and also have installed cm12 custom ROM in it. I also have install cwm recovery . but before 3 week I just tried to on my but it doesn't I looked out some videos from YouTube which says to connect your phone with your laptop I done that it start charging I felt very good I kept it for a day .next try to on that it stared but after some 'Samsung galaxy tab 2 GT p3100 ' it started my recovery I am help less now now I always try to do that it does the same thing ....... Plz help .............
vermaujjwal2 - Antwoord
wrong answer to that tablet section
Ron Andres -
My Galaxy Tab kept rebooting. We removed the battery and then reassembled everything and now it won't start at all. Ideas?
Jan Morrow - Antwoord
@tvljan You removed the battery, put it back together and it doesn't start? You did REPLACE the battery, right? Otherwise it's not surprising it doesn't start. The other possible issue could be that when you replaced the battery (assuming you did) that the connection clip/plug didn't make a proper connection or that something in the socket broke when you removed the old battery. It's been some months, so maybe you have figured it out, but I post that in case others have a similar problem... it's most likely a simple cause, whether or not the solution is simple.
Lowell Montgomery -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 64
Altijd: 45,590
