Inleiding
In this guide, you will learn how to replace the battery on your Samsung Galaxy Tab 10.1. Having a bad or broken battery can be frustrating. There are a couple prerequisites we need to get out of the way first!
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
61 andere personen hebben deze handleiding voltooid.
20 opmerkingen
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
good jobs man
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
