Inleiding
In this guide you will remove the entire SIM card reader assembly. This is not a complicated process, just make sure you don't misplace the 4 screws.
Wat je nodig hebt
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
Use a Phillips #00 screwdriver to remove all 4 black 2.5mm screws securing the silver SIM card reader to the motherboard.
Één andere persoon heeft deze handleiding voltooid.
