Ga door naar hoofdinhoud
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 3, afbeelding 3 van 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to pry the speakers out of the tablet
Conclusie
Guneet Bawa
679 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G5, Liner Spring 2018 Lid van UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 348
