Ga door naar hoofdinhoud
Samsung Galaxy Stardust Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy Stardust Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Galaxy Stardust Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold down the power button located on the right side of the phone.
    • After five seconds, the screen will display three different options. Select the "power off" option.
  2. Samsung Galaxy Stardust Battery Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy Stardust Battery Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy Stardust Battery Replacement: stap 2, afbeelding 3 van 3
    • Place your finger or opening tool in the hole on the side of the phone.
    • Carefully pull the back casing away from the phone while keeping the phone stable.
  3. Samsung Galaxy Stardust Battery Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy Stardust Battery Replacement: stap 3, afbeelding 2 van 2
    • Place both the phone and the phone casing next to each other with the battery facing upwards.
    • Carefully lift the battery from the indent above the battery, then place the battery next to the phone.
  4. Samsung Galaxy Stardust Battery Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Stardust Battery Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Stardust Battery Replacement: stap 4, afbeelding 3 van 3
    • Take your new battery and look for the plus and minus signs on the bottom of the battery.
    • Line up the signs to the three strips on the bottom of the phone.
    • Carefully place the battery in until it is secure inside the phone.
  5. Samsung Galaxy Stardust Battery Replacement: stap 5, afbeelding 1 van 1
    • Take the back of the phone and line up the circular hole to the camera.
    • Apply force to the back of the phone with your hand, until the back case snaps onto the phone and is secure.
Eindstreep
Alan Kwong
121 Reputatie
1 Handleiding geschreven
2 opmerkingen
bom dia como concertar o samsung A32
camargowil - Antwoord
bom dia podem me mandar ,para mim e outros armenque o esquema eletrico do samsung A32=SM-A32 5M/DS
como desmontar e se possivel o esquema eletrico.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 101
Altijd: 1,860
