Ga door naar hoofdinhoud
Samsung Galaxy Sol Rear Camera Replacement
Wat je nodig hebt
  1. Samsung Galaxy Sol Rear Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Rear Camera Replacement, Rear Camera: stap 3, afbeelding 1 van 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
  5. Samsung Galaxy Sol Rear Camera Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Sol Rear Camera Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Sol Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
  6. Samsung Galaxy Sol Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Once you detach the chips, remove the hard drive to access the rear camera.
  7. Samsung Galaxy Sol Rear Camera Replacement: stap 7, afbeelding 1 van 2 Samsung Galaxy Sol Rear Camera Replacement: stap 7, afbeelding 2 van 2
    • To remove the rear camera, flip the tab upward and then pull the camera straight out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 488
