Ga door naar hoofdinhoud
Samsung Galaxy Sol Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Sol Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Headphone Jack Replacement, Headphone Jack: stap 3, afbeelding 1 van 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Turn the phone around and remove the screen using the plastic tool.
  5. Samsung Galaxy Sol Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the headphone jack at the top of of the phone by carefully removing it with tweezers.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 334
