Ga door naar hoofdinhoud
Inleiding
Using these steps, you can replace the volume button on your Galaxy SIII Mini VE.
Onderdelen
Geen onderdelen opgegeven.
  1. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: stap 1, afbeelding 1 van 3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: stap 1, afbeelding 2 van 3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: stap 1, afbeelding 3 van 3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Battery: stap 2, afbeelding 1 van 2 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Battery: stap 2, afbeelding 2 van 2
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Screws: stap 3, afbeelding 1 van 1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy SIII Mini VE Volume Button Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy SIII Mini VE Volume Button Replacement: stap 4, afbeelding 2 van 2
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: stap 5, afbeelding 1 van 3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: stap 5, afbeelding 2 van 3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: stap 5, afbeelding 3 van 3
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Volume Button: stap 6, afbeelding 1 van 2 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Volume Button: stap 6, afbeelding 2 van 2
    • Locate the volume button.
    • Using the tweezers, life the volume button up and away from the phone.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Megan
1.186 Reputatie
6 handleidingen geschreven
Michigan Tech, Team 1-8, Lauer Fall 2014 Lid van Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Leden
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 825
