Ga door naar hoofdinhoud
Samsung Galaxy SIII Mini VE Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: stap 1, afbeelding 1 van 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: stap 1, afbeelding 2 van 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: stap 1, afbeelding 3 van 3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: stap 2, afbeelding 1 van 2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: stap 2, afbeelding 2 van 2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: stap 3, afbeelding 1 van 2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: stap 3, afbeelding 2 van 2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Megan
1.186 Reputatie
6 handleidingen geschreven
Michigan Tech, Team 1-8, Lauer Fall 2014 Lid van Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 3,306
