Ga door naar hoofdinhoud
Samsung Galaxy SIII Mini Display Assembly Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 2 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 2
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
    Screw size is PH00, and they're all the same size, so don't worry about getting any of them mixed up! :)
    Craig Jessup - Antwoord
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 3, afbeelding 3 van 3
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 5, afbeelding 3 van 3
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 7, afbeelding 3 van 3
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 8, afbeelding 3 van 3
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 9, afbeelding 3 van 3
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 10, afbeelding 1 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 10, afbeelding 2 van 3 Samsung Galaxy SIII Mini Display Assembly Replacement: stap 10, afbeelding 3 van 3
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: stap 11, afbeelding 1 van 1
    • That's all.
    • Did you do it successfully?
Conclusie
18 andere personen hebben deze handleiding voltooid.
ZFix
191.278 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
2 opmerkingen
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Antwoord
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 17,497
