Ga door naar hoofdinhoud
Samsung Galaxy S9 Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy S9 Headphone Jack Replacement, Rear Glass Removal: stap 1, afbeelding 1 van 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Headphone Jack Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S9 Headphone Jack Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S9 Headphone Jack Replacement: stap 3, afbeelding 3 van 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
  4. Samsung Galaxy S9 Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Headphone Jack Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S9 Headphone Jack Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S9 Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
  6. Samsung Galaxy S9 Headphone Jack Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  7. Samsung Galaxy S9 Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  8. Samsung Galaxy S9 Headphone Jack Replacement, NFC Antenna and Charging Coil: stap 8, afbeelding 1 van 1
    • Remove the eight 4 mm Phillips #00 screws.
  9. Samsung Galaxy S9 Headphone Jack Replacement: stap 9, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement: stap 9, afbeelding 2 van 2
    • Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
    • Twist or pry to release the plastic clips securing the cover.
  10. Samsung Galaxy S9 Headphone Jack Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement: stap 10, afbeelding 2 van 2
    • Insert an opening pick under the left side of the plastic cover.
  11. Samsung Galaxy S9 Headphone Jack Replacement: stap 11, afbeelding 1 van 1
    • Remove the plastic cover containing the NFC antenna and charging coil.
  12. Samsung Galaxy S9 Headphone Jack Replacement, Battery Disconnection: stap 12, afbeelding 1 van 1
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  13. Samsung Galaxy S9 Headphone Jack Replacement, Unfasten Motherboard Cover: stap 13, afbeelding 1 van 1
    • Remove the two 4 mm Phillips #00 screws holding the plastic cover in place.
  14. Samsung Galaxy S9 Headphone Jack Replacement, Remove Motherboard Cover: stap 14, afbeelding 1 van 1
    • Remove the plastic cover from the motherboard.
  15. Samsung Galaxy S9 Headphone Jack Replacement, Unfasten Loudspeaker Assembly: stap 15, afbeelding 1 van 1
    • Remove the five 3.5 mm Phillips #00 screws.
  16. Samsung Galaxy S9 Headphone Jack Replacement: stap 16, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement: stap 16, afbeelding 2 van 2
    • Insert an opening pick underneath the top edge of the loudspeaker assembly.
    • Use the opening pick to pry up the loudspeaker assembly.
  17. Samsung Galaxy S9 Headphone Jack Replacement, Remove Loudspeaker Assembly: stap 17, afbeelding 1 van 1
    • Remove the loudspeaker assembly.
  18. Samsung Galaxy S9 Headphone Jack Replacement, Unfasten Headphone Jack: stap 18, afbeelding 1 van 1
    • Remove the 3.5 mm Phillips #00 screw.
  19. Samsung Galaxy S9 Headphone Jack Replacement, Disconnect Headphone Jack: stap 19, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement, Disconnect Headphone Jack: stap 19, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the headphone jack flex cable.
  20. Samsung Galaxy S9 Headphone Jack Replacement, Remove Headphone Jack: stap 20, afbeelding 1 van 2 Samsung Galaxy S9 Headphone Jack Replacement, Remove Headphone Jack: stap 20, afbeelding 2 van 2
    • Use a pair of tweezers to remove the headphone jack.
Conclusie
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After you've completed the repair, follow this guide to test your repair.
Secure the fingerprint sensor with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
203.160 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.767 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 55
Altijd: 3,483
