Ga door naar hoofdinhoud
Samsung Galaxy S9 Charging Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy S9 Charging Port Replacement, Rear Glass Removal: stap 1, afbeelding 1 van 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Charging Port Replacement: stap 2, afbeelding 1 van 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Charging Port Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 3, afbeelding 3 van 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
  4. Samsung Galaxy S9 Charging Port Replacement: stap 4, afbeelding 1 van 2 Samsung Galaxy S9 Charging Port Replacement: stap 4, afbeelding 2 van 2
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Charging Port Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 5, afbeelding 3 van 3
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
  6. Samsung Galaxy S9 Charging Port Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S9 Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  7. Samsung Galaxy S9 Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  8. Samsung Galaxy S9 Charging Port Replacement, Midframe assembly: stap 8, afbeelding 1 van 1
    • Remove fifteen 4mm screws with a #000 Phillips screwdriver.
  9. Samsung Galaxy S9 Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Remove the NFC coil assembly.
  10. Samsung Galaxy S9 Charging Port Replacement: stap 10, afbeelding 1 van 1
    • Remove the motherboard bracket.
  11. Samsung Galaxy S9 Charging Port Replacement: stap 11, afbeelding 1 van 1
    • Remove the speaker cover/antenna assembly.
  12. Samsung Galaxy S9 Charging Port Replacement, Charging Port: stap 12, afbeelding 1 van 1
    • Remove five 3mm screws #000 Phillips screwdriver.
  13. Samsung Galaxy S9 Charging Port Replacement: stap 13, afbeelding 1 van 1
    • Disconnect three cables.
    • If your replacement charging port does not come with the blue and white cables, you will need to remove them from your old board in order to connect your new one.
  14. Samsung Galaxy S9 Charging Port Replacement: stap 14, afbeelding 1 van 1
    • Remove the headphone jack by using a spudger to pry it free.
  15. Samsung Galaxy S9 Charging Port Replacement: stap 15, afbeelding 1 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 15, afbeelding 2 van 3 Samsung Galaxy S9 Charging Port Replacement: stap 15, afbeelding 3 van 3
    • Remove charging port board.
Conclusie
33 andere personen hebben deze handleiding voltooid.
Sam Azevedo
736 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G6, White Winter 2019 Lid van Cal Poly, Team S1-G6, White Winter 2019
CPSU-WHITE-W19S1G6
4 Leden
29 handleidingen geschreven
8 opmerkingen
Hi, does the screen need to be replaced once the charging port has been replaced?
Elliot Lawrence - Antwoord
Hi Elliot! If you replace your charging port, you will need to replace the back cover, but the screen should remain intact. It is very difficult to remove the back cover without breaking it (unless you have access to a heat gun), so if you’re thinking about replacing your charging port, you may want to get a new back cover ready beforehand. Good luck and Happy Fixing!
Ani Svadjian -
A lot of parts missing to this guide.
Kara Monster - Antwoord
Hi there, is there anything you would recommending replacing/updating/upgrading while you have the phone disassembled? Thanks!
Callum Eve - Antwoord
This guide is decent, but it was not my primary reference for this task. IMO a better guide can be found here: https://www.youtube.com/watch?v=o1NYvdkZ...
Eric Makara - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 70
Afgelopen 30 dagen: 273
Altijd: 43,973
