Ga door naar hoofdinhoud
Samsung Galaxy S8 SIM Card Tray Replacement
Wat je nodig hebt
  1. Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: stap 1, afbeelding 1 van 3 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: stap 1, afbeelding 2 van 3 Samsung Galaxy S8 SIM Card Tray Replacement, SIM Card: stap 1, afbeelding 3 van 3
    • Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
    • Press to eject the tray.
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
Conclusie
After you've completed the repair, follow this guide to test your repair.
8 andere personen hebben deze handleiding voltooid.
Adam O'Camb
196.194 Reputatie
416 handleidingen geschreven
5 opmerkingen
Is this sim tray water proof with the rubber seal or no?
And what colors does it come in?
Darryl Bass - Antwoord
Is the Galaxy S8 similar to the Galaxy S8+ ?
travislwright2016 - Antwoord
Is installing the SIM card in the Galaxy S8 similar to installing the SIM card into the Galaxy S8+ ?
My tray actually broke off inside it, I could not remove it far enough to even get the sim card in it, only the sd card, is there a way to open it up?
Eric Hogarth - Antwoord
Did you find a way?
Jonathan Tsikire -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 89
Afgelopen 30 dagen: 359
Altijd: 36,226
